Which FPGA IP can be used FREE in production with the Quartus LITE dev. sw?
- 2 years ago
I tested a bit in Quartus Prime Light (20.1.1) for a MAX10 (10M50DA type), and these are some findings.
- It seems it's the more elaborate IPs that needs paid licenses (as has been said), so PLLs, use of ADC in MAX10, etc. are free
- You can disable use og Evaluation licenses:
Assignments > Settings > Compilation Process Settings > More Settings > Intel FPGA IP Evaluation Mode: Disable
- In the Compilation Report you can check (examples when disabled):
- Assembler > Encrypted IP Cores Summary (Gives for example: Nios II Embedded...: Unlicensed; Signal Tap: Licensed)
- Assembler > Messages (gives for example)
- 115003 Can't generate programming files ... not valid license for following IP core(s)
115005 Unlicensed IP: "Nios II Embedded Processor Encrypted output..."
115004 Unlicensed encrypted design file: "c:/....../altera_nios_gen2_rtl_module.sv"- When Evaluation mode is Enabled, you get the programming file <name>_time_limited.sof (as Frank said earlier).
- You can also check in the Compilation Report
- Analysis & Synthesis > IP Cores Summary, the Licence Type column
For example: Signal Tap: Licensed; no licence needed (it seems): N/A, Nios II Embedded...: OpenCore (not free)(Nios II is btw outdated, Nios V should be used for new designs, but it needs a paid license as well.)
So, I'm a bit more optimistic, seems that much of the simpler IP in Platform Designer in Quartus can be used.
In Lite, you don't really get anything without paying for it. https://www.intel.com/content/www/us/en/products/programmable/intellectual-property/ip-base-suite.html
Does that mean you can't use the PLLs, ADs etc. in MAX 10 run in production without paying for IP?
- sstrell2 years ago
I don't know what the differentiators are, but basic hardware operations like PLLs and ADC and such are always available. It's the add-on functional IP where licensing starts.
- SmallBusinessOwner2 years ago
Thanks. Is there a way I can see in Quartus Lite what is add-on functional IP and what counts as basic hardware operation?
No. I always joke that they should put little dollar signs next to the IP that requires licensing.
