What's the EPCQL Page Program sequence when using Serial Flash IP on a Cyclone 10GX with PCIe core? Is there a special way when the IP is hooked up to the PCIe core Avalon bus?
I just remove the JTAG Master IP and observed the timing analysis. Nothing much changes.
- JBayl6 years ago
Hi John,
Here's our code:
// NEW for testing Config SPI Flash FPGA IP core
#define REG_FLASH_IP_CSR 0x10000000 // offset from PCIe BAR2 base address
// the following are offsets from REG_FLASH_IP_CSR
#define FLASH_CONTROL_REG 0x00 // Control register bit8 1=4byte add,keep bit0 at 1, 0 = disable outputs
#define FLASH_OP_PROTO_SET 0x10 // Operating Protocol Setting Register
#define FLASH_RD_INST_REG 0x14 // Read Instruction Register
#define FLASH_WR_INST_REG 0x18 // Write Instruction Register
#define FLASH_CMD_SET 0x1C //31-21 reserved|20-16 #dummy cycles|15-12 #w/r data bytes|11 0=wr 1=rd|10-8 #address bytes|7-0 opcode|
#define FLASH_CMD_START 0x20 //write 1 to start
#define FLASH_ADDRESS 0x24 // address for the operation
#define FLASH_WR_DATA0 0x28 // first 4 bytes write data
#define FLASH_WR_DATA1 0x2C // last 4 bytes write data
#define FLASH_RD_DATA0 0x30 // first 4 bytes read data
#define FLASH_RD_DATA1 0x34 // last 4 bytes read data
#define FLASH_IP_MEM 0x8000000
#define FPGA_ONCHIP_MEM 0x100000
void PCIJTAG2_API FlashIpStuff(void)
U32 DataRead;
WritePciJtag(REG_FLASH_IP_CSR+FLASH_OP_PROTO_SET,0x0); // normal extended mode for all operations
// Read Device IDs
WritePciJtag(REG_FLASH_IP_CSR+FLASH_CMD_SET,0x000489F); // opcode 9F, no address, write bit 11 set = read, 4 bytes, 0 dummy cycles
WritePciJtag(REG_FLASH_IP_CSR+FLASH_CMD_START,0x01); // execute Command
DataRead = ReadPciJtag(REG_FLASH_IP_CSR+FLASH_RD_DATA0);
printf("\nDeviceID = 0x%x\n",DataRead);
// Clear sector protect by writing the status Register
WritePciJtag(REG_FLASH_IP_CSR+FLASH_CMD_SET,0x00001001); // opcode 01, write bit 0 = write
WritePciJtag(REG_FLASH_IP_CSR+FLASH_WR_DATA0, 0x20); // bit 5 for bottom start - all protect bits cleared
// Enter 4 byte addressing
FlashSetWriteEnable();
WritePciJtag(REG_FLASH_IP_CSR+FLASH_CMD_SET,0x000000B7); // write opcode b7 - no address or data bytes
WritePciJtag(REG_FLASH_IP_CSR+FLASH_CONTROL_REG,0x00000101); // Tell Flash IP we are using 4-byte addressing
FlashEraseSector(0xB000000); // sector 11 64KB sectors
WritePciJtag(REG_FLASH_IP_CSR+FLASH_WR_INST_REG,0x00007012); // 70h status read, 12h 4-byte page program opcode
WritePciJtag(FLASH_IP_MEM+0xB00000,0xFACEFACE);
CheckStatus();
WritePciJtag(REG_FLASH_IP_CSR+FLASH_RD_INST_REG,0x00000013); // 0 dummy cycles 13h 4-byte read opcode
DataRead = ReadPciJtag(FLASH_IP_MEM+0xB00000);
printf("\nDataRead = 0x%x\n",DataRead);
void FlashSetWriteEnable(void)
WritePciJtag(REG_FLASH_IP_CSR+FLASH_CMD_SET, 0x00000006);// write opcode 6
void FlashEraseSector(U32 address)
// Erase using 4 byte address
WritePciJtag(REG_FLASH_IP_CSR+FLASH_CMD_SET,0x000004D8); // write opcode D8 sector erase - 4 address bytes
WritePciJtag(REG_FLASH_IP_CSR+FLASH_ADDRESS,address); // address
void CheckStatus(void)
U32 DataRead,i=0;
do
Sleep(5);
WritePciJtag(REG_FLASH_IP_CSR+FLASH_CMD_SET,0x0004870);//status read of 4 bytes of data
}while((DataRead != 0x81818181)&& (i < 500));
Output:
DeviceID = 0x1021bb20
DataRead = 0xffffffff
