JRubi5
7 years agoWhat is the proper way to interface in Quartus Prime Platform Designer the avalon_st_rx and avalon_st_tx ports in a Low Latency 100G Ethernet Intel Stratix 10 FPGA IP Core.
These Avalon ports are built as Conduits in the Ethernet IP, and not as Avalon Streaming ports. The streaming clock signal is included in the Conduit. My own IP needs to have an Avalon Sink port an...
JRubi5
7 years agoThanks for your effective answer.
I have defined in the VHDL design file the following port signals, compliant with the standard Avalon nomenclature:
Csi_StClock_clk : in std_logic;
Cso_StClock_clk : out std_logic;
I have made this assignment in the architecture:
Cso_StClock_clk <= clk_rxmac;
where clk_rxmac is bundled among the signals in the Conduit that is driven by the Ethernet IP.
Then in Platform Designer I have signal Cso_StClock_clk drive the input of a clock bridge IP. The output of the clock bridge IP drives Csi_StClock_clk, and this is the signal specified as a clock for the various Avalon source ports in the Signals and Interfaces tab of the Component Editor.
