14 years agoWaitrequest ALTMEMPHY DDR2 Controller
Hi, I have a problem with the ALTMEMPHY DDR2 Controller. I try to build a FIFO using the external DDR2 ram. In principle, the FIFO works but I do not achieve the required speed. With a (own wri...
14 years agoHi BadOmen
Many thanks for your help. You were right! Now it works as desired. Thanks to your hint I found this issue also described in the documentation for the ALTMEMPHY. Best regards Christian
