14 years agoWaitrequest ALTMEMPHY DDR2 Controller
Hi, I have a problem with the ALTMEMPHY DDR2 Controller. I try to build a FIFO using the external DDR2 ram. In principle, the FIFO works but I do not achieve the required speed. With a (own wri...
14 years agoHi BadOmen
Many thanks for your answer. So the first thing I did was to remove the beginbursttransfer signal but nothing changed. Then I checked the parameters of the DDR2 Controller and the clocking. Unfortunately, I can’t find an error. There are some screenshots in the attachment. Some more information that may be important: - Using Quartus II version 12 - FPGA: EP4CE75F23C8N - DDR2 RAM: W971GG6JB-25 - RAM is connected to Bank7 and Bank8 (thus on the top I/O banks, right?) Thanks a lot and best regards Christian
