Viterbi License Requirements
There are two Viterbi license types : IP-Viterbi/HS and IP-Viterbi/SS
/HS is the parallel implementation. /SS is the hybrid
We have the /HS licensed.
When building a design with the core in it (v17.1 Pro), we receive errors that the /SS license is missing.
The IP Summary in the A&S Report says High Speed Viterbi Decoder and says we are Licensed.
The synthesis flow messages say :
Warning(18390): Intel FPGA IP Evaluation Mode (Simulation-Only) feature is turned on for all cores in the design
Warning(18394): Some cores in this design do not support the Intel FPGA IP Evaluation Mode feature
Warning(18395): "Low Speed Viterbi Decoder" does not support the Intel FPGA IP Evaluation Mode feature
The assembler then says :
Warning(115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Warning(115005): Unlicensed IP: "Low Speed Viterbi Decoder(6AF7 0038)"
Warning(115004): Unlicensed encrypted design file: "D:/work/shaw/achilles_sdr_fec/build/qdb/_compiler/achilles_sdr/root_partition/17.1.2/final/1/names.model"
Warning(115004): Unlicensed encrypted design file: "D:/work/shaw/achilles_sdr_fec/build/qdb/_compiler/achilles_sdr/root_partition/17.1.2/final/1/netlist.model"
The parallel implementation is picked in the IP wizard.
Is there a dependency?
-Brian
- SZack
Hi Vikas,
Thanks for identifying that this is a bug and for providing a link to the workaround. I guess Brian was the first customer to encounter this bug since the KDB article was just added recently
