14 years agoVIP Frame buffer not reading
Hi, We are currently investigating an issue where our VIP frame buffer is not issuing any reads on the Master read port. We have a Frame buffer configured to drop/duplicate and drop erro...
14 years agoHi,
What happens if you uncheck the tick box to drop errored frames? If the read side works consistently after such a change but you cannot get a proper video output from your system then it probably means that the frame buffer is receiving invalid control packets and/or image packets with incorrect size. There could be a configuration issue with one of the core upstream. Also, check for overflow at the input if you are using the VIP Clocked Video Input. vgs
