15 years agoVIP Frame buffer & HPC II ddr2 problem
I've been building up a VIP video system in SOPC builder with QII ver10.1. I am having a problem getting the external ddr2 to run. I have checked all the normal hardware types of things... (power,...
13 years agoI have a doubt.
Is the frame buffer itself to control the data flow if i have a pattern generator as an input data and a clocked video output as an output data? (both from the VIP). or Is it necessary to use the Nios II for this case? I tested the HPC II ddr2 controller out of QSys and is working, but when I integrate all these cores in Qsys I dont see anything. Thank you, Juan
