15 years agoVIP Frame buffer & HPC II ddr2 problem
I've been building up a VIP video system in SOPC builder with QII ver10.1. I am having a problem getting the external ddr2 to run. I have checked all the normal hardware types of things... (power,...
15 years agoOutside of SOPC builder you should get a generated example top project with Altmemphy and an altera test driver. I would check this is working first. If it is then its likely that you have a problem connecting clocks or resets within SOPC builder.
