17 years agoVideo Suite and a TI TVP5150
Has anyone had any success getting the clocked video input block to process bt656 from a TI TVP5150? I'm not having much luck with this. I was told by Altera that the 5150 doesn't work correctly wi...
17 years agoFound my problem. It turns out that my default parameter for the input image height needed to be bumped up from 244 to 252. I also increased the fifo size, for good measure. The video is now streaming through as it should.
