11 years agoVideo Processing Problem
I am using Cyclone III Development Board and I want to take an input from computer via Bitec DVI receiver and directly pass it to monitor via Bitec DVI transmitter.
Here is the code, I used and I could not achieve what I want and have no idea why does it not work ? Appriciate your answers entity top is port( clk : in std_logic; BITEC_DVI_IO_IN : in std_logic_vector(23 downto 0); BITEC_DVI_IO_IN_DE : in std_logic; BITEC_DVI_IO_IN_HSYNC : in std_logic; BITEC_DVI_IO_IN_ODCK : in std_logic; BITEC_DVI_IO_IN_VSYNC : in std_logic; BITEC_DVI_IO_OUT_HSYNC : out std_logic; BITEC_DVI_IO_OUT_DE : out std_logic; BITEC_DVI_IO_OUT : out std_logic_Vector(23 downto 0); BITEC_DVI_IO_OUT_VSYNC : out std_logic; BITEC_DVI_IO_OUT_DVI_ISEL : out std_logic; BITEC_DVI_IO_OUT_DVI_PD : out std_logic; BITEC_DVI_IO_OUT_DVI_DKEN : out std_logic; BITEC_DVI_IO_OUT_DVI_CTL1 : out std_logic; BITEC_DVI_IO_OUT_DVI_CTL2 : 0ut std_logic; BITEC_DVI_IO_OUT_DVI_CTL3 : out std_logic; BITEC_DVI_IO_OUT_IDCKp : out std_logic; BITEC_DVI_IO_OUT_IDCKn : out std_logic ); end top; architecture behavioral of top is component vidout2 port ( is_clk : in std_logic := '0'; -- is_clk_rst.clk rst : in std_logic := '0'; -- is_clk_rst_reset.reset is_data : in std_logic_vector(23 downto 0) := (others => '0'); -- din.data is_valid : in std_logic := '0'; -- .valid is_ready : out std_logic; -- .ready is_sop : in std_logic := '0'; -- .startofpacket is_eop : in std_logic := '0'; -- .endofpacket vid_clk : in std_logic := '0'; -- clocked_video.export vid_data : out std_logic_vector(23 downto 0); -- .export underflow : out std_logic; -- .export vid_datavalid : out std_logic; -- .export vid_v_sync : out std_logic; -- .export vid_h_sync : out std_logic; -- .export vid_f : out std_logic; -- .export vid_h : out std_logic; -- .export vid_v : out std_logic -- .export ); end component; component vidin port ( is_clk : in std_logic := '0'; -- is_clk_rst.clk rst : in std_logic := '0'; -- is_clk_rst_reset.reset is_data : out std_logic_vector(23 downto 0); -- dout.data is_valid : out std_logic; -- .valid is_ready : in std_logic := '0'; -- .ready is_sop : out std_logic; -- .startofpacket is_eop : out std_logic; -- .endofpacket vid_clk : in std_logic := '0'; -- clocked_video.export vid_data : in std_logic_vector(23 downto 0) := (others => '0'); -- .export overflow : out std_logic; -- .export vid_datavalid : in std_logic := '0'; -- .export vid_locked : in std_logic := '0'; -- .export vid_v_sync : in std_logic := '0'; -- .export vid_h_sync : in std_logic := '0'; -- .export vid_f : in std_logic := '0' -- .export ); end component; signal locked :std_logic:='0'; signal c0,ready,valid,eop,sop,underflow,overflow,f,h,v: std_logic:='0'; signal data : std_logic_vector(23 downto 0):=(others=>'0'); begin l2: vidin port map(clk,'0',data,valid,ready,sop,eop,BITEc_DVI_IO_IN_ODCK,BItEC_DVI_IO_IN,overflow,BITEC_DVI_IO_IN_DE,'1',BITEC_DVI_IO_IN_VSYNC,BITEC_DVI_IO_IN_HSYNC,f); l3: vidout2 port map(clk,'0',data,valid,ready,sop,eop,BITEc_DVI_IO_IN_ODCK,BITEC_DVI_IO_OUT,underflow,BITEC_DVI_IO_OUT_DE,BITEC_DVI_IO_OUT_VSYNC,BITEC_DVI_IO_OUT_HSYNC,f,h,v); BITEC_DVI_IO_OUT_IDCKp<=BITEC_DVI_IO_IN_ODCK; BITEC_DVI_IO_OUT_DVI_ISEL<='1'; BITEC_DVI_IO_OUT_DVI_PD <='0'; BITEC_DVI_IO_OUT_DVI_DKEN <='0'; BITEC_DVI_IO_OUT_DVI_CTL1 <='0'; BITEC_DVI_IO_OUT_DVI_CTL2 <='0'; BITEC_DVI_IO_OUT_DVI_CTL3 <='0'; BITEC_DVI_IO_OUT_IDCKn <='0'; end behavioral;1 Reply
I did not look in deep to your code, but for a simple loopback you would just need wires from the input to the output.
Could you provide a bigger picture of your system as I see some Avalon-ST Signals in your components...
