  • LSant1's avatar
    LSant1
    Hi Chee Pin,
    I did try it in Platform Designer after getting input from Vikas. But initially I was not able to see the VIP suite under DSP as the VIP core was loaded in C:\intelfpga_pro\18.1\ip\altera\ folder. So I copied the VIP folder under C:\intelfpga_pro\18.1\ip\altera\dsp and was able to view it. But even after deleting the vip suite from dsp folder, the platform designer is now able to show the vip suite under C:\intelfpga_pro\18.1\ip\altera. Its ok now.
    Lakshmi
  • CheepinC_altera's avatar
    CheepinC_altera
    Hi, Sorry for the inconvenience with the web link. Regarding your inquiry on purchasing the license for VIP, just would like to check with you if you are aware of your local sales from Intel? If yes, it is recommended for you to get in touch with them so that they could further assist you on the license purchase. If not, you may visit the following webpage to check for the nearest sales to your location. https://www.intel.com/content/www/us/en/programmable/buy/intellectual-property.html Please let me know if there is any concern. Thank you. Best regards, Chee Pin
  • Hi Lakshmi,
    Glad to hear that your environment set is working now. We appreciate yours patient on the communication interaction here. Do let us know if you need any further assistant regarding this issue.
    If we are all set for now, please also acknowledge if we can treat this case as a "closed" for now.
    Joseph
    Intel Customer Support
  • Hi Nicholas, @LeeTechnology​ ​
    For your concerned about broken link below:
    Please open a new thread so that we can address this to Internal IT team to work on it. This is for a better tracking purpose and also serve other forums user at correct thread when they following communication posting.
    Regarding the SSLC, please give it a try on this specific link:
    Licensing Center Request:
    https://fpgasupport.intel.com/Licensing/license/index.html
    Licensing Center Main Page:
    https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/licensing.html
    Do clear your cache and cookies then reopen the link. If it still doesn't work at your case, please file a new thread and our support personnel will assist you on the request.
    Joseph
