15 years agoUsing UniPHY leaving RUP and RDN unconnected for a DDR2 SDRAM controller
is there a way to implement a UniPHY DDR2 SDRAM controller leaving RUP and RDN pins unconnected i.e. without OCT?
15 years agoThis is also driving me crazy. I have a DDR3 core and a QDR core, both using UNIPHY, and created inside SOPC. Both cores bring out the rup,rdn pins in the VHDL ports of the Nios core,
but when I wire them up to the real pins I get the errors stating the pins are already busy. I also see auto generated rup and rdn pins in the log files for these cores. Which one is it Quartus?? I "Think" what is going on is that I have constraints that set the pins to 50 Ohm termination. I'm testing a theory that this causes Quartus to generate the OCT hardware automagically which then interferes with the manually instantiated cores in SOPC. I commented out the 50 Ohm settings in my constraints and am trying again. Is this documented somewhere? OCT - auto vs manual instantiation?
