17 years agoUsing SODIMM DDR2 module on Cyclone 3
Hi All,
Hope someone can help. I'm just trying to establish the feasibility of using a SODIMM memory DDR2 memory module (e.g Micron MT16HTS25664H) with a Cyclone III FPGA (EP3C40F484C6 or 7). This is the 2Gbyte part, though we could potentially want to use the 4Gbyte part. We currently have a Cyclone 2 FPGA on the board as it stands, with a 32Mbyte DDR memory chip (not module) which works very well. However we need to expand the memory capabilities and memory modules seem to offer substantial cost savings. I'm concerned that the memory bus width of the SODIMM module is 64bits and the documentation seems to imply that this would not be supported by the Cyclone 3 and the DDR2 controller block from Altera. Does anyone have experience of driving SODIMM modules using a Cyclone 3? many thanks Richard.11 Replies
I encountered the same problem. In Cyclone4 devices, only 1 side cannot support a DIMM with 200 pins. If we use DIMM in cyclone series, 2 sides at least should be used. It's harder to achieve higher frequency when using 2 sides, but 167MHz could be guarrented.
