17 years agoUsing SODIMM DDR2 module on Cyclone 3
Hi All, Hope someone can help. I'm just trying to establish the feasibility of using a SODIMM memory DDR2 memory module (e.g Micron MT16HTS25664H) with a Cyclone III FPGA (EP3C40F484C6 o...
13 years agoI encountered the same problem. In Cyclone4 devices, only 1 side cannot support a DIMM with 200 pins. If we use DIMM in cyclone series, 2 sides at least should be used. It's harder to achieve higher frequency when using 2 sides, but 167MHz could be guarrented.
