VenkateshSathar
7 years agousing DSPs in the FPGA as ALMs for standard FFT IP
Hi, We are using standard FPGA FFT IP for our design given by intel. we want to use many FFT IPs parallely for that the problem that we are seeing is resources for ALMs required is not suffiecient ...
KennyT_altera
7 years agoHave you follow the above steps that given? If you follow the steps, you should not have the question how to make it happened.
Basically, Quartus detect hw.tcl files for all the IP that is using. If you move over the whole dsp folder, all the necessary files will be copied over and you will see it like I mention above.
- VenkateshSathar7 years ago
I am unable to download you 18.1 software now i think due to some other problems of your website. because for any account login for download coming like this only. After solving this by you guys only I can try i think so😕
