VenkateshSathar
7 years agousing DSPs in the FPGA as ALMs for standard FFT IP
Hi, We are using standard FPGA FFT IP for our design given by intel. we want to use many FFT IPs parallely for that the problem that we are seeing is resources for ALMs required is not suffiecient ...
KennyT_altera
7 years agoAlso, you will need to recreate the IP in Q16.1 to make it work, in your project navigators -> Ip components -> double check the IP is using 18.1 version
- VenkateshSathar7 years ago
how to make it happen to use 18.1 FFT in 16.1 quartus software. For that also some background folders of the IP in installation need to copy from 18.1 is it?
