VenkateshSathar
7 years agousing DSPs in the FPGA as ALMs for standard FFT IP
Hi, We are using standard FPGA FFT IP for our design given by intel. we want to use many FFT IPs parallely for that the problem that we are seeing is resources for ALMs required is not suffiecient ...
KennyT_altera
7 years agoMay be you can create one simplified design and post it here. I will help you to sort this out.
VenkateshSathar
7 years agoadded a project with only fft2048 ip and added the attributes also. since I am used to vhdl , you will see top module with vhdl. here also same situation as discussed only ALMS consuming. quartus 16.1.2 I used. And for my other developments also using same quartus version.
