8 years ago
Using ALTLVDS TX with changeable datarate
Hi all,
I have a request where I need to drive two different LVDS 7:1 displays (different resolutions/frequencies/data rates) over the same LVDS interface using the same FPGA design.
Which display is used is SW programmable.
Can I use altlvds_tx with internal PLL, generated with the datarate settings for the faster display, and hope that the slower will work too since they both use serialization factor 7?
Or do I have to use external PLL and then reprogram it with new settings depending on which display is used?
Or is there a way to reprogram ALTLVDS_TX with the new datarate?
Thank you.
1 Reply
    Hi ana, can you help me am a beginner I need direction to become a sound programmer
