jjang
3 years agoUsing Altera PLL make 500Khz or below
When i Using ALTPLL, i Usually make 500khz and below xx kHz Frequency Clock. @ 50Mhz / 100Mhz Input clock. But Cyclone 5, Different PLL IP Core. - ALTPLL → Altera PLL, so it doesn't support fo...
- 3 years ago
just read PLL Intel FPGA IP messages thoroughly. It instructs you to enable physical output clock pararameters to configure cascaded output counters.
AqidAyman_Altera
3 years agoHi,
I wish to follow up on this issue. Have you able to use the cascading feature to generate the low frequencies output clock?
Aqid
