9 years agoUnable to place and Route altera_iopll in my design with Quartus 16.1 Pro Edition
Hi, I have a design which uses altera_iopll. I'm trying to synthesize the design using Synplify_Premier 2016.09-SP1 and Place & Route using Quartus 16.1 Pro Edition. I'm able to generate the .v...
9 years agoHi psc,
there is an issue with the iopll in Quartus Prime Pro 16.1, if you are in urgent need of help you will have to contact the Altera support otherwise use the older releases or wait for the next patch. Cheers, fade
