9 years ago
UFM initialization - how to reach sector 2?
Hi everyone, (this is my 1rst post here)
I'm trying to use the UFM macro on a MAX 10 - 04. I've generated a customized IP (see parameters below, as set by QSys ip generator). I've also generated a .dat file (see below) with 18432 32-bits values, for UFM initialization.
In my simulation test bench I read some addresses of it. It does work for lower addresses (up to 0x4000), but for higher addresses (as soon as i try to read 0x5000) I get wrong values, like 0xFFFFFFFF (see attached waveform!)... as if the memory hasn't been initialized with the .dat values.
This seems to match with the start of "sector 2" as defined in the module parameters by qsys.
How can I initialize these higher addresses, at least in simulation?
laurent
onchip_flash_0 : component altera_onchip_flash
        generic map (
            INIT_FILENAME                       => "nvm.hex",
            INIT_FILENAME_SIM                   => "nvm_simu.dat",
            DEVICE_FAMILY                       => "MAX 10",
            PART_NAME                           => "10M04SAU169I7G",
            DEVICE_ID                           => "04",
            SECTOR1_START_ADDR                  => 0,
            SECTOR1_END_ADDR                    => 4095,
            SECTOR2_START_ADDR                  => 4096,
            SECTOR2_END_ADDR                    => 25087,
            SECTOR3_START_ADDR                  => 0,
            SECTOR3_END_ADDR                    => 0,
            SECTOR4_START_ADDR                  => 0,
            SECTOR4_END_ADDR                    => 0,
            SECTOR5_START_ADDR                  => 0,
            SECTOR5_END_ADDR                    => 0,
            MIN_VALID_ADDR                      => 0,
            MAX_VALID_ADDR                      => 25087,
            MIN_UFM_VALID_ADDR                  => 0,
            MAX_UFM_VALID_ADDR                  => 25087,
            SECTOR1_MAP                         => 2,
            SECTOR2_MAP                         => 3,
            SECTOR3_MAP                         => 0,
            SECTOR4_MAP                         => 0,
            SECTOR5_MAP                         => 0,
            ADDR_RANGE1_END_ADDR                => 25087,
            ADDR_RANGE1_OFFSET                  => 4608,
            ADDR_RANGE2_OFFSET                  => 0,
            AVMM_DATA_ADDR_WIDTH                => 15,
            AVMM_DATA_DATA_WIDTH                => 32,
            AVMM_DATA_BURSTCOUNT_WIDTH          => 4,
            SECTOR_READ_PROTECTION_MODE         => 31,
            FLASH_SEQ_READ_DATA_COUNT           => 2,
            FLASH_ADDR_ALIGNMENT_BITS           => 1,
            FLASH_READ_CYCLE_MAX_INDEX          => 4,
            FLASH_RESET_CYCLE_MAX_INDEX         => 8,
            FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX  => 38,
            FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX => 11200000,
            FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX => 9760,
            PARALLEL_MODE                       => true,
            READ_AND_WRITE_MODE                 => false,
            WRAPPING_BURST_MODE                 => false,
            IS_DUAL_BOOT                        => "False",
            IS_ERAM_SKIP                        => "True",
            IS_COMPRESSED_IMAGE                 => "False"
nvm_simu.dat file: it is a nice 18432-lines ramp
00000000
00000001
00000002
00000003
000047FA
000047FB
000047FC
000047FD
000047FE
000047FF
