15 years agoUDP for TSE MAC
Hi all, Currently I am using TSE MAC, but is there any UDP Verilog module already available to connect with TSE MAC? I tried to search around but can not find one. Thanks a lot!
15 years agoIt seems that there is something wrong in your bsp generation... The acceleration components have this line in their *_sw_tcl file:
set_sw_property auto_initialize falseand this should instruct the tools not to put the *_INIT macros in the alt_sys_init() function. What version of quartus/Nios do you use? I tried to compile the example with both 8.0 and 9.0SP2 (I don't have 10.0) and in both cases it created the alt_sys_init() without those macro calls. Did you do any change to the *_sw.tcl files in the components? As a temporary workaround you can comment those lines in alt_sys_init.c, but you,ll need to do that again each time it is regenerated: void alt_sys_init( void )
ALTERA_AVALON_TIMER_INIT( SYS_CLK_TIMER, sys_clk_timer );
ALTERA_AVALON_TIMER_INIT( HIGHT_RES_TIMER, hight_res_timer );
ALTERA_AVALON_TIMER_INIT( STAT_TIMER, stat_timer );
ALTERA_AVALON_CFI_FLASH_INIT( EXT_FLASH, ext_flash );
ALTERA_AVALON_JTAG_UART_INIT( JTAG_UART, jtag_uart );
ALTERA_AVALON_SYSID_INIT( SYSID, sysid );
TRIPLE_SPEED_ETHERNET_INIT( TSE_MAC, tse_mac );
ALTERA_AVALON_SGDMA_INIT( SGDMA_TX, sgdma_tx );
ALTERA_AVALON_SGDMA_INIT( SGDMA_RX, sgdma_rx );
PRBS_PACKET_GENERATOR_INIT( GENERATOR_0, generator_0 );
PRBS_PACKET_GENERATOR_INIT( GENERATOR_1, generator_1 );
PRBS_PACKET_GENERATOR_INIT( GENERATOR_2, generator_2 );
PRBS_PACKET_GENERATOR_INIT( GENERATOR_3, generator_3 );
UDP_PAYLOAD_INSERTER_INIT( UDP_INSERTER_0, udp_inserter_0 );
UDP_PAYLOAD_INSERTER_INIT( UDP_INSERTER_1, udp_inserter_1 );
UDP_PAYLOAD_INSERTER_INIT( UDP_INSERTER_2, udp_inserter_2 );
UDP_PAYLOAD_INSERTER_INIT( UDP_INSERTER_3, udp_inserter_3 );
ERROR_PACKET_DISCARD_INIT( ERROR_DISCARD, error_discard );
UDP_PORT_TO_CHANNEL_MAPPER_INIT( UDP_MAPPER, udp_mapper );
OVERFLOW_PACKET_DISCARD_INIT( OVERFLOW_DISCARD, overflow_discard );
UDP_PAYLOAD_EXTRACTOR_INIT( EXTRACTOR_0, extractor_0 );
UDP_PAYLOAD_EXTRACTOR_INIT( EXTRACTOR_1, extractor_1 );
UDP_PAYLOAD_EXTRACTOR_INIT( EXTRACTOR_2, extractor_2 );
UDP_PAYLOAD_EXTRACTOR_INIT( EXTRACTOR_3, extractor_3 );
PRBS_PACKET_CHECKER_INIT( CHECKER_0, checker_0 );
PRBS_PACKET_CHECKER_INIT( CHECKER_1, checker_1 );
PRBS_PACKET_CHECKER_INIT( CHECKER_2, checker_2 );
PRBS_PACKET_CHECKER_INIT( CHECKER_3, checker_3 );
} As for your second questions, the packets generated or received by the hardware have the Ethernet, IP and UDP header in addition to the data, so this may be why they look different. In this system you can have both hardware and software handled packets. The idea is to handle the low bandwidth traffic in software (through the standard BSD sockets API, including recvfrom) and handle the high bandwidth traffic directly in hardware (through the acceleration components).
