14 years agoTV Decoder to VGA on DE2-115 using VIP Suite
Hello, I am writing this post just to share a sample project (see the attached zip) for the DE2-115 board which grabs video frames from the onboard the ADV7180 TV Decoder and outputs them to 640x4...
14 years agoHi,
I have tried to use those presets in the design but with failure.So I worked out with the presets I got from a design example from bitec which was totally different from what we see when we set the ones predefined in the panel suggested. I have not been able to get a working design with DVI.Most of the example designs are with VGA.So I am having difficulty in setting the vip suite parameters for DVI (which should have been easier that is what we thought while starting the project) Thanks for your help.Do you have an idea what is the maximum clock we can use in the vip suite components?It definitely is less than 150 MHz although I got CVI and CVO output at 150 with reasonable clarity of picture but failed with other vip suite components.
