14 years agoTV Decoder to VGA on DE2-115 using VIP Suite
Hello, I am writing this post just to share a sample project (see the attached zip) for the DE2-115 board which grabs video frames from the onboard the ADV7180 TV Decoder and outputs them to 640x4...
14 years agoHi,
I also want to know if for different image data format in CVI and CVO do we need different parameter values for horizontal sync vertical sync horizontal front porch back porch and other parameters to be set in the window.Because I see from your design that your output is also DVI and you have different parameters than I have although I am using image size of 1920 by 1080 and yours is different .Can you tell me how to calculate or find those parameters?
