14 years ago
TV Decoder to VGA on DE2-115 using VIP Suite
I am writing this post just to share a sample project (see the attached zip) for the DE2-115 board which grabs video frames from the onboard the ADV7180 TV Decoder and outputs them to 640x480 VGA through the ADV7123 DAC using only SoPC and the VIP suite.
The DE2_115_TV example contained in the Terasic DVD, which is the only example working with PAL sources I was able to find on the internet, does not take advantage of the VIP suite, rather relies on custom verilog modules, IMHO very difficult to integrate in other designs (especially when NIOS is involved)
I wasted several days in order to make it work with the VIP suite (clocked video input -> chroma resample -> ... -> deinterlacer ->clocked video output) and it was quite hard for me to find enough documentation to configure properly the timing parameters of the clocking video I/O and the correct sequence for decoding ITU-R.656 to RGB.
I am sharing this project (which works correctly with both PAL and NTSC sources) with the hope that it will help someone else in the future that encounters the same problem as mine.
Note: this example uses the SDRAM memory for keeping the 640x480 RGB frame-buffer. I have another working variant which uses the smaller SRAM (2 Mb) for the FB, downsampling the captured frames to 320x240 and then upsampling to 640x480 before the video_output. Feel free to contact me if you need it.
Primiano
