14 years agoTV Decoder to VGA on DE2-115 using VIP Suite
Hello, I am writing this post just to share a sample project (see the attached zip) for the DE2-115 board which grabs video frames from the onboard the ADV7180 TV Decoder and outputs them to 640x4...
14 years agoHi,
I am trying to do almost the same design but with DVI input and output. I have been able to achieve only a part of it. The part where I can get input from the CVI -> frame buffer -> DDR2 memory -> CVO works fine but when I try to introduce other vip suite components such as chroma sampler or even a simple clipper it gives me no results.Can you help me with the correct parameters for DVI if you have any?
