14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
9 years agoHi Michael,
--- Quote Start --- I hope it’s okay to dig up this thread. --- Quote End --- Sure :) I wrote the quartus_stp as a work-around while I figured out the SystemConsole version. Earlier versions of SC had a broken Tcl implementation, but I'm pretty sure it got fixed - look at the Tcl code, I'm usually pretty good at leaving comments in there. Given that Altera/Intel probably isn't putting any effort into quartus_stp, I'd recommend using SystemConsole. I think from your comments above SC is working for you. If not, let me know, and I'll fire up a board and see if I can break it in the same way you do. Cheers, Dave
