14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years agoHi Dave,
thanks for the answer and offer to provide some .svg files. Coincidentally, I installed Inkscape a couple of weeks ago in order to draw a (very simple) diagram for a paper I had to prepare. So yes, if you would provide some of your svg files (e.g. figures 18 and 29 from your ftdi.pdf), I'd be happy to have a look into it in order to see, if I could use this for some of my documentation, too. Very kind offer of yours, thank you! Regards, Maik
