14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years agoHi Maik,
--- Quote Start --- this is a little bit "off topic", but what (I suppose) Latex package do you use for your timing diagrams? --- Quote End --- I use Inkscape (a free drawing tool). It generates nice .pdf files and understands how to tear a PDF apart, so I can extract pages from data sheets, pull the images into Inkscape, and then annotate the images. For the timing diagrams, I just draw things by hand ... time consuming the first time, but most of the time I just start with a previous diagram. I can post the Inkscape .svg file for anything you'd like so you can play with it. Just ask. Cheers, Dave
