14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years ago --- Quote Start --- Just use the JTAG-to-Avalon-MM bridge and connect it as another master to the memory. Cheers, Dave --- Quote End --- But on the pc side, it's there an altera tool to transfer data, or would it require a custom (tcl) application. For example, I found this but also doesn't seem to be for bust transfers.: Goo.gl/JKcw2M
