14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years agoAny suggestions on how (or if) the usb-blaster avalon jtag master could be used to transfer a block of memory that sits on the avalon bus? I'm trying to debug a video buffer, and it would be super useful if I could pull the raw binary data directly from memory, repeatedly, and as fast as the blaster protocol allows.
