14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years agoHi Dave,
Thanks again for your response. The board I am using is a board created for the group that I work with. We are trying to consolidate and only have one communication interface, hence my interest in moving things to the jtag port. The main usage of the communication interface will be to grab some data that I've stored in the Avalon-MM. The interface speed won't really be an issue but from what I've looked at it's going to be pretty difficult to implement. Would you mind sending me the links? Thanks!!
