14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years ago --- Quote Start --- Re-reading my question, I realize I didn't actually mean a Nios II processor. (All this work with Altera tools lately has tied C to Nios in my mind) I wanted to move away from needing to run a tcl script in SystemConsole. For a clearer picture, the board I am working with only has a JTAG to USB connection to the connecting PC. I was hoping to use this connection to do reads/writes to the Avalon MM. Your tutorial accomplishes the second part of my goal but not the ability to not need the Altera toolset. I think your second answer where you talk about replacing this logic with C-code is what I need to do and have it run on my host computer. --- Quote End --- Both answers provide options. The question is, which is the least amount of work? Does your board have GPIO pins connected to 100-mil headers? If so, then using an FTDI cable is by far the simplest solution. If you really like beating yourself up, then I can give you some links to the reverse-engineered USB-Blaster protocol ... but honestly, the interface is not that fast, so it is a lot of work, for very little gain. Which board are you using? Cheers, Dave
