14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years agoHey Dave,
Thanks for the answer... I know I should use simulation. If you take a look at the other thread I mentioned above, you see that I test everything using signal tap. Maybe you have something to add to the questions, I asked over there. Since I don't use 8/10b encoding just like the transceiver toolkit examples, I wonder how I perform alignment myself. I haven't found that particular part in the TTkit until now, where the alignment takes place.... Thanks, Maik
