14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years agoHi Maik,
--- Quote Start --- The main question really is, if I have to take care about anything but my data I would like to transmit? e.g., do I have to check myself for word alignment patterns although I have set this up in the transceiver phy component in QSys. --- Quote End --- The answer is "it depends". Since it depends on how you've setup the transceiver. If you control both ends of the link, then you can use the 8/10B encoders and have the transceiver recover the synchronization. If you do not use 8/10B encoding, then you have to synchronize the links yourself. For example, I have used the transceiver sync pattern detect logic, and hard-coded it to the start of a PRBS sequence and used that to synchronize lanes. The main thing is, get it working in simulation first! :) Cheers, Dave
