14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years agoHi Maik,
What kind of transceiver problems are you suffering from? I've suffered from a few myself :) Using Debian should be fine. I typically check my stuff with Centos to make sure things work under Linux. Cheers, Dave
