14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
10 years agoHey Dave,
I'm still struggling with the client/server applications, but had no time to continue on that for since the beginning of the week..... I use the transceiver toolkit on our custom board succesfully, so I think the JTAG-to-Avalon-MM bridge does work correctly from system console because I can control all transceivers in both FPGAs without any problems. Since it seems that I have a major misunderstanding in transceivers, I will focus on that first and come back to this issue in a couple of days..... By the way, you are talking about using the cygwin shell.... I'm using a Debian Linux anyway, so I try to perform everything from the linux console, but in my opinion that should not be the cause for my problems.... what do you think? Regards, Maik
