14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
11 years agoHi Tim,
--- Quote Start --- Thanks for your suggestion. I fixed the problem after I changed VTAP with dut.jtag_master.jtag_phy_embedded_in_jtag_master.genclk1.node in tb. --- Quote End --- Glad that you managed to fix it! Cheers, Dave
