14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
12 years ago --- Quote Start --- I would like to take a look at your tutorial but the sadly the links doesn't work for me. Can you take a look at it? Can you provide another download links? --- Quote End --- The Altera Wiki link is: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial That page links to documents that are stored here (along with other tutorials you may be interested in); http://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html Cheers, Dave
