14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
13 years ago --- Quote Start --- How come that System Console and quartus_stp are so slow? --- Quote End --- If you're using a recent version of ACDS then SystemConsole provides the master_write_from_file command which is even faster (providing you have your data available as a binary file)
