14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
13 years ago --- Quote Start --- First of all, thank you for putting this tutorial together. It's very well written and it's been a great resource. --- Quote End --- You're welcome. --- Quote Start --- Unfortunately for me, I'm having some issues getting the jtag-to-Avalon-MM bridge to work on a Altera Stratix IV dev board, 530 edition. I'm able to get everything to compile, and everything passes in simulation. However, after programming the FPGA, and using quartus_stp to issue commands from Figure 15, I get the following error:tcl> jtag_write 0 0 0x23 Error: incorrect number of response bytes! Everything up to that point works. The jtag_open, jtag_print_hub_info and jtag_print_node_info all produce the expected result. Do you have any ideas what could be going on here? --- Quote End --- Any reason why you're using quartus_stp? If you are just using the command line, then SystemConsole works fine. I was using it today on the 230K version of the same board. I won't be at work tomorrow, but I'll see if I can find the issue with quartus_stp on Friday. For now, why not try using SystemConsole - look at the jtag_cmds_sc.tcl scripts in the boards area. Which version of Quartus are you using? Cheers, Dave
