14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
13 years agoHi Dave,
Just to let you know I completed the the quartus_stp -s session as well. It works fine (on a monkey see, monkey do) basis. ;-) One thing I noticed is that reading the ram on an not-times-4 address gives a different result then in System Console. The read value 'shifts around'. Why? Rgds, Kimberleyhttps://www.alteraforum.com/forum/attachment.php?attachmentid=6450
