14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
13 years agoHi Dave,
Another question I have is the following: On page 37 I read the sentences: --- Quote Start --- “The Tcl fileevent command is critical to the implementation of a Tcl TCP/IP server. Versions of Systems Console earlier than Quartus II version 11.1sp1 did not support the Tcl filevent procedure…” --- Quote End --- This would mean that the program won’t run in my quartus 10.1 version? Do you have a solution for this? For example is it possible to split this up? Meaning, if I install also quartus 11.1sp1 and run this tcl server/client program from a 11.1sp1 quartus_sh terminal, can I then still communicate to my sopc system generated in quartus 10.1? Rgds, Kimberley
