14 years agoTSE "small MAC" isn't asserting fifo_rx_dsav signal for min size Eth frames
I have a "Small MAC" instantiation of the TSE for a 100 Mbit link. It appears that it isn't asserting the fifo_rx_dsav signal for small messages. When we try to ping our DUT (device under test) fro...
14 years agoHi jehodny,
I have the same troubles as you! Using "arp -s " to set the MAC address of each, ping, telnet, ... are working. I though on first that it was a SW problem (ARP filtering), but I've just discovered that a "ping -s 22" that sends 22 + 8 ICMP data are not received, when "ping -s 23" are. Did you found a solution? Can one use the full version with a 10/100 design? -- Fred
