18 years agoTSE newbie starter questions
Hey there I have started working with the Altera tools and some Hardware at my university lately I have a Stratix2GX Board and managed to use the onchip mem and ram and check if everything is f...
18 years agoYour description is very vague. Do be clear if you would like the answer you want.
"tried the TSE Benchmark template to work on my design." -- you mean the Simple Socket Server sample application or what? I assume you are. If not what it is? Any application note newly published? the UCOSII and Interniche application notes? "With this new bunch of code I tried to just get access to my LEDs and let them blink but i cannot get even one line of code working, properly because i don't know where to start." -- What bunch of code, you write yourself or what? if you are using the sample application, what you mean it doesn't work? doesn't it compiles? You access the application through the TSE by telnet?
