18 years agoTSE newbie starter questions
Hey there I have started working with the Altera tools and some Hardware at my university lately I have a Stratix2GX Board and managed to use the onchip mem and ram and check if everything is f...
18 years agoWell ... your explanation isn't exactly clear. You say you added the TSE MAC and it's necessary components to your SOPC system. There are example designs in the example folder of your NIOS II EDS install. In short, you will need:
1 - The TSE MAC 2 - Two SGDMA controllers (one for transmit and one for receive) 3 - Onchip memory (to store the descriptors for the SGDMA controllers) Once you've added all those to your system and connected them appropriately, you'll need to build your SOPC system. Then you'll have to edit your top level project file (Verilog, or schematic maybe?) and connect all of the port from the TSE MAC to the appropriate pins on the FPGA. I'm assuming your Stratix II GX board has a PHY on it correct? Jake
