rt52
6 years agoTSE IP core on MAX10 not working
I have a custom board with a MAX10 and 2 TI DP83869 PHYs that are meant to transfer ethernet data from one PHY to the other through the MAX10. However, I cannot seem to get data to appear from the i...
SengKok_L_Intel
6 years agoHi,
Thank you for the reply.
- Do you initial a pattern generator to transmit the data when perform the local loopback test (e.g Pattern Generator -> TX -> Local loopback -> RX)?
- Is the local loopback work well in dev kit, but not your custom board?
- When perform the local loopback test, did you check the TSE IP Avalon ST interface? Are there any activities (both TX and RX)?
- If you suspect this is external PHY issue, I would suggest you to contact the third party vendor to advice.
Regards -SK
- rt526 years ago
1) I am not sure where to find the pattern generator. Would I have to make one myself or is there one I could use? I did not see anything in the datasheet regarding that.
2) I will have to try that, but if the packet generator is an issue, I would guess not.
3) So I interrupted the pipeline latch that connects one MAC to the other and viewed in signal tap and saw I had data coming out of of the first MAC, but I still did not see any status registers update from my UART module. Could you think of any reason why the status register would not update? I have them enabled in the platform designer instantiation.
4) I am in contact with the PHY manufacturer trying to tackle this issue from both sides
