13 years agoTSE demultiplexer switch based on supplementary mac addr
Hi, I was thinking about routing the the avalon streaming output from a TSE mac to several different avalon streaming inputs. The obvious choice is to use an avalon streaming de-multiplexer blo...
13 years agoTo answer the original question no I don't think there is any way to extract directly an address number from the TSE. Without access to the source code it isn't possible to add this directly to the core, so you will have to develop an external component with one input stream connected to the TSE and several output streams (or one output stream with a channel number, that you connect to a demultiplexer).
