13 years agoTSE demultiplexer switch based on supplementary mac addr
Hi, I was thinking about routing the the avalon streaming output from a TSE mac to several different avalon streaming inputs. The obvious choice is to use an avalon streaming de-multiplexer blo...
13 years agoThere is UDP port to Avalon-ST channel adapter available in UDP offload example project. You can use that file to make Your own adapter and use it in Your application. I've rewritten that module in VHDL plus added some more features... It actually works fine by default, but I don't know verilog that much.
